Postprocessor Installation/Update Guide
When you receive an updated or custom post processor from SolidCAM, follow these steps to locate your current directory and correctly install the new files.
Step 1: Verify Your Current Post Processor Location
Before copying any new files, you need to find where your system currently looks for them.
- Close any open SolidCAM or InventorCAM files, but keep SolidWorks or Autodesk Inventor open.
- Open your CAM settings depending on your software:
- For SolidCAM users: Go to the main menu and click Tools > SolidCAM > SolidCAM Settings.
- For InventorCAM users: Click the CAM Settings button located in the InventorCAM ribbon.
- In the settings window, select the Default CNC-Controller page from the left-hand menu.
- Look at the top field on the right side labeled Post-Processor files directory.
Note: Post Processor files must reside in a folder namedGPPTOOL. The standard installation path is typically:C:\Users\Public\Documents\SolidCAM\SolidCAM20XX\GPPTOOL - Note this file path down, then completely close SolidWorks or Autodesk Inventor.
Step 2: Extract and Save the New Post Processor Files
SolidCAM post processors consist of two vital files: a .gpp file and a .vmid file.
- Open the email sent to you by SolidCAM Tech Support.
- Download the attached files.
⚠️ IMPORTANT: If the files were sent in a.ziparchive, you must extract them first. Right-click the folder and select Extract All before moving them. - Copy and paste the new
.gppand.vmidfiles into theGPPTOOLdirectory path you located in Step 1. - When prompted by Windows to overwrite the existing files, choose Copy and Replace (or Accept).
Step 3: Verify the Update
- Restart SolidWorks or Autodesk Inventor.
- Re-open an existing SolidCAM or InventorCAM project file.
- Generate your G-Code to confirm that the changes have been successfully applied.
If you also need to install a Machine Simulation, follow the instructions here:
Machine Simulation Installation Guide
If you encounter any issues during the installation or if your G-Code does not output correctly, please reply directly to your active support ticket or contact SolidCAM Technical Support.
